The superimposition of ESTELLE programs : a tool for the implementation of observation and control algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1989
Benoit Caillaud
The superimposition is a distributed program composition. It is a concenient concept for the design and implementation of control and observation algorithms in distributed systems, such as snapshots, detection of termination, global time, verification of properties, mutual exclusion, garbage collection. The present report describes the implementation of superimposition on static Estelle. It consists of a compiler that transforms a program in static Estelle extended to the superimposition into a pure static Estelle program. The problem of the correctness and complexity of the generated code is also raised.
Autre [cs.OH]
RR-1102.pdf (1.26 Mo) Télécharger le fichier
inria-00075457 , version 1 (24-05-2006)
  • HAL Id : inria-00075457 , version 1
Benoit Caillaud. The superimposition of ESTELLE programs : a tool for the implementation of observation and control algorithms. [Research Report] RR-1102, INRIA. 1989. ⟨inria-00075457⟩
51 Consultations
44 Téléchargements
