HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Programming with MALI. The interpretation of Prolog programs
Louis Chevallier 1 Serge Le Huitouze 1 Olivier Ridoux 1
1 MALI - Mise en oeuvre des langages de programmation logique
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Résumé : Disponible dans les fichiers attachés à ce document
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075511
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:22:17 PM
Last modification on : Friday, February 4, 2022 - 3:16:24 AM
Long-term archiving on: : Friday, May 13, 2011 - 12:33:07 PM
Identifiers
  • HAL Id : inria-00075511, version 1
Citation
Louis Chevallier, Serge Le Huitouze, Olivier Ridoux. Programming with MALI. The interpretation of Prolog programs. [Research Report] RR-1048, INRIA. 1989. ⟨inria-00075511⟩
Share
Metrics
Record views
134
Files downloads
26
