Abstract : This paper is devoted to the two-product problem with joint production costs and independent inventory costs. It gives an algorithm which leads to the optimal policy in the infinite horizon case. This algorithm is the extension of the celebrated E0Q formula which was obtained for the mono-product problem.
https://hal.inria.fr/inria-00076191
Contributor : Rapport de Recherche Inria <>
Submitted on : Wednesday, May 24, 2006 - 8:17:41 PM Last modification on : Thursday, February 11, 2021 - 2:48:12 PM Long-term archiving on: : Friday, May 13, 2011 - 4:57:49 PM
Alain Bensoussan, Jean-Marie Proth. Economical ordering quantities for the two products problem with joint production costs. [Research Report] RR-0365, INRIA. 1985, pp.19. ⟨inria-00076191⟩
