HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Artificial memory in production management
Abstract : The scheduling of parts in a production system is an NP-complete problem. To search an optimal solution is incompatible with the "real time" constraint. The usual procedures (clusters-job, introduction of constraints on the fabrication starting time, hierarchical schedulind) all contribute to vanish the combinatorial aspect of the problem. We propose to memorize some behaviour-classes and to use them in order to choose the management rule in relation with the aimed targets. A numerical example will describe this approach.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00076221
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 8:21:53 PM
Last modification on : Friday, February 4, 2022 - 3:22:10 AM
Long-term archiving on: : Friday, May 13, 2011 - 6:02:41 PM
Identifiers
  • HAL Id : inria-00076221, version 1
Collections
Citation
Evelyne Bechler, Jean-Marie Proth, Kosta Voyiatzis. Artificial memory in production management. [Research Report] RR-0336, INRIA. 1984, pp.16. ⟨inria-00076221⟩
Share
Metrics
Record views
87
Files downloads
26
