Three dimensional reconstruction of complex shapes based on the Delaunay triangulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
We propose a solution to the problem of 3D reconstruction from cross sections, based on the Delaunay triangulation of object contours. Its properties-especially the close relationship to the medial axis-enable us to do a compact tetrahedrisation resulting in a nearest-neighbor connection. The reconstruction of complex shapes is improved by adding vertices on and inside contours.
Autre [cs.OH]
RR-1697.pdf (509.55 Ko) Télécharger le fichier
inria-00076934 , version 1 (29-05-2006)
  • HAL Id : inria-00076934 , version 1
Jean-Daniel Boissonnat, Bernhard Geiger. Three dimensional reconstruction of complex shapes based on the Delaunay triangulation. [Research Report] RR-1697, INRIA. 1992. ⟨inria-00076934⟩
253 Consultations
785 Téléchargements
