Texture analysis using fractal probability functions
Abstract : In this work, we use iterations of contractive functions to build textures. At each iteration, one of the contractions is chosen at random according to place-dependent probabilities. This scheme allows to encode and reconstruct exactly a wide class of textured images, thus providing a compact representation usable for analysis and data compression.
Type de document :
Rapport
[Research Report] RR-1707, INRIA. 1992
Liste complète des métadonnées
https://hal.inria.fr/inria-00076944
Contributeur : Rapport de Recherche Inria <>
Soumis le : lundi 29 mai 2006 - 11:39:27
Dernière modification le : vendredi 25 mai 2018 - 12:02:06
Document(s) archivé(s) le : vendredi 13 mai 2011 - 20:54:16
Fichiers
  • HAL Id : inria-00076944, version 1
Collections
Citation
Jacques Lévy Véhel. Texture analysis using fractal probability functions. [Research Report] RR-1707, INRIA. 1992. 〈inria-00076944〉
Métriques
Consultations de la notice
112
Téléchargements de fichiers
78
