Compressible flow solvers using unstructured grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
This document contains a detailed review of works performed at INRIA related to the MUSCL-FEM upwind method for unstructured meshes (revised notes of a lecture given at Van Karman Institute).
Autre [cs.OH]
RR-1732.pdf (4.15 Mo) Télécharger le fichier
inria-00076971 , version 1 (29-05-2006)
  • HAL Id : inria-00076971 , version 1
Alain Dervieux, Jean-Antoine Desideri. Compressible flow solvers using unstructured grids. [Research Report] RR-1732, INRIA. 1992. ⟨inria-00076971⟩
204 Consultations
150 Téléchargements
