Stochastic timed event graphs : bounds, cycle time reachability and marking optimization - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1992
This paper addresses the performance evaluation and optimization of stochastic timed event graphs. The transitions firing times of such a timed event graph are random variables with general distribution. We first establish an upper bound and a lower bound for the average cycle time of the timed event graph. We prove that any cycle time greater than the greatest mean transition firing time can be reached by putting enough tokens in each place. The necessary and sufficient condition of the reachability of the greatest mean firing time is established. We then address the marking optimization problem which consists in obtaining a given cycle time while minimizing a linear criterion depending on the initial marking.
RR-1763.pdf (1.08 Mo) Télécharger le fichier
Dates and versions
inria-00077003 , version 1 (29-05-2006)
Identifiers
  • HAL Id : inria-00077003 , version 1
Cite
Jean-Marie Proth, Nathalie Sauer, Xiaolan Xie. Stochastic timed event graphs : bounds, cycle time reachability and marking optimization. [Research Report] RR-1763, INRIA. 1992, pp.18. ⟨inria-00077003⟩
188 View
91 Download
Share
