Abstract : In this paper we study the convergence of sequential quadratic programming algorithms for the nonlinear programming problems. Assuming only that the direction is a stationary point of the current quadratic program we study the local convergence properties without strict complementarity. We obtain some global and superlinearly convergent algorithm. As a particular case we formulate an extension of Newton's method that is quadratically convergent to a point satisfying a strong sufficient second order condition.
