HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
About cache associativity in low-cost shared memory multi-microprocessors
Nathalie Drach 1 Alain Gefflaut 2 Philippe Joubert 2 André Seznec 1
1 CALCPAR - Calculateurs Parallèles
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
2 LSP - Langages et Systèmes Parallèles
Abstract : In 1993, sizes of on-chip caches on current commercial microprocessors range from 16 Kbytes to 36 Kbytes. These microprocessors can be directly usedin the design of a low cost single-bus shared memory multiprocessors with-out using any second-level cache. In this paper, we explore theviability of such a multi-microprocessor. Simulations results clearly establish that performance of such a system will be quite poor if on-chip caches are direct-mapped. On the other hand, when the on-chip caches are partially associative, the achieved level of performance is quite promising. In particular, two recently proposed innovative cache structures, the skewed associative cache organization and the semi-unified cache organization are shown to work fine.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00077193
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, May 29, 2006 - 5:17:05 PM
Last modification on : Friday, February 4, 2022 - 3:25:26 AM
Long-term archiving on: : Monday, April 5, 2010 - 9:42:07 PM
Identifiers
  • HAL Id : inria-00077193, version 1
Citation
Nathalie Drach, Alain Gefflaut, Philippe Joubert, André Seznec. About cache associativity in low-cost shared memory multi-microprocessors. [Research Report] RR-2083, INRIA. 1993. ⟨inria-00077193⟩
Share
Metrics
Record views
159
Files downloads
184
