On Super-High-Frequencies in Discontinuous 1st-Order Delay-Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
One considers a scalar 1st-order nonlinear differential equation with a delayed relay-output proportional feedback. One shows that, under a boundedness condition on the nonlinearity only, any solution of this equation has, after a finite time, a finite number of zeros on compact sets. An estimate of the time after which the super-high-frequency disappears is provided. This improves some previous works by Shustin. As a consequence, using some works by Fridman et al., any solution of the system under study coincides, after a finite time, with one of the periodic solutions.
RR-3443.pdf (379.45 Ko) Télécharger le fichier
inria-00077201 , version 1 (29-05-2006)
  • HAL Id : inria-00077201 , version 1
Marianne Akian, Pierre-Alexandre Bliman. On Super-High-Frequencies in Discontinuous 1st-Order Delay-Differential Equations. [Research Report] RR-3443, INRIA. 1998. ⟨inria-00077201⟩
159 Consultations
149 Téléchargements
