Unification via Explicit Substitutions: The Case of Higher-Order Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Gilles Dowek
  • Fonction : Auteur
Thérèse Hardin
  • Fonction : Auteur
Frank Pfenning
  • Fonction : Auteur
In [6] we have proposed a general higher-order unification method using a theory of explicit substitutions and we have proved its completeness. In this paper, we investigate the case of higher-order patterns as introduced by Miller. We show that our general algorithm specializes in a very convenient way to patterns. We also sketch an efficient implementation of the abstract algorithm and its generalization to constraint simplification, which has yielded good experimental results at the core of a higher-order constraint logic programming language.
RR-3591.pdf (448.72 Ko) Télécharger le fichier
inria-00077203 , version 1 (29-05-2006)
  • HAL Id : inria-00077203 , version 1
Gilles Dowek, Thérèse Hardin, Claude Kirchner, Frank Pfenning. Unification via Explicit Substitutions: The Case of Higher-Order Patterns. [Research Report] RR-3591, INRIA. 1998, pp.33. ⟨inria-00077203⟩
137 Consultations
148 Téléchargements
