Equivariant HPD credible sets and MAP estimators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bayesian Analysis Année : 2007
MAP estimators and HPD credible sets are often criticized in the literature because of paradoxical behaviour due to a lack of equivariance under reparametrization. In this paper, we propose a new version of MAP estimators and HPD credible sets that avoid this undesirable feature. Moreover, in the special case of non-informative prior, the new MAP estimators coincide with the equivariant frequentist ML estimators. We also propose several adaptations in the case of nuisance parameters.
RR-5921.pdf (212.16 Ko) Télécharger le fichier
inria-00077906 , version 1 (01-06-2006)
inria-00077906 , version 2 (06-06-2006)
  • HAL Id : inria-00077906 , version 2
Pierre Druilhet, Jean-Michel Marin. Equivariant HPD credible sets and MAP estimators. Bayesian Analysis, 2007, 2 (4), pp.681-692. ⟨inria-00077906v2⟩
300 Consultations
161 Téléchargements
