A constructive and unifying framework for zero-bit watermarking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
In the watermark detection scenario, also known as zero-bit watermarking, a watermark, carrying no hidden message, is inserted in content. The watermark detector checks for the presence of this particular weak signal in content. The article looks at this problem from a classical detection theory point of view, but with side information enabled at the embedding side. This means that the watermark signal is a function of the host content. Our study is twofold. The first step is to design the best embedding function for a given detection function, and the best detection function for a given embedding function. This yields two conditions, which are mixed into one `fundamental' partial differential equation. It appears that many famous watermarking schemes are indeed solution to this `fundamental' equation. This study thus gives birth to a constructive framework unifying solutions, so far perceived as very different.
Unifying.pdf (417.26 Ko) Télécharger le fichier
inria-00078445 , version 1 (08-06-2006)
inria-00078445 , version 2 (12-01-2007)
Teddy Furon. A constructive and unifying framework for zero-bit watermarking. 2006. ⟨inria-00078445v1⟩
244 Consultations
436 Téléchargements
