Hardware/Software Exploration for an Anti-collision Radar System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Anti-collision radars help prevent car accidents by detecting obstacles in front of vehicles equipped with such systems. This task traditionally relies on a correlator, which searches for similarities between an emitted and a received wave. Other modules can then use the information produced by the correlator to compute the distance and the relative speed between the moving vehicle and the obstacle. We implemented such a system using FPGAs. We used hardware blocks to implement the high demanding computing correlator and a soft-core processor to compute the distances and speeds. In order to improve the maximum detection distance reached by the correlation algorithm, we developed and tested a modified version of a Higher Order Statistics based algorithm. This work results in a detailed description of this new algorithm, its possible implementations and the corresponding FPGA synthesis results.
MWCAS06.pdf (770.26 Ko) Télécharger le fichier
inria-00079054 , version 1 (08-06-2006)
  • HAL Id : inria-00079054 , version 1
Sébastien Le Beux, Vincent Gagné, El Mostpaha Aboulhamid, Philippe Marquet, Jean-Luc Dekeyser. Hardware/Software Exploration for an Anti-collision Radar System. Midwest Symposium on Circuits and Systems, Institute of Electrical and Electronics Engineers, IEEE Circuits and Systems Society, Electrical and Computer Engineering Department, Aug 2006, San Juan/ Puerto Rico. ⟨inria-00079054⟩
100 Consultations
474 Téléchargements
