Reports
Well-posedness results for non-autonomous dissipative complementarity systems
Abstract : This paper deals with the well-posedness of a class of nonsmooth dynamical systems: dissipative complementarity systems. Both the linear and the nonlinear cases are treated, and the systems are non-autonomous. The dissipativity property is used to perform a particular change of state vector which allows one to transform the dynamics into a perturbed Moreau's sweeping process. As an example an electrical circuit with ideal diodes is presented.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00079220
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, June 13, 2006 - 10:42:38 AM
Last modification on : Saturday, March 6, 2021 - 3:19:10 AM
Long-term archiving on: : Thursday, September 23, 2010 - 4:13:08 PM
Identifiers
  • HAL Id : inria-00079220, version 3
Collections
Citation
Bernard Brogliato, Lionel Thibault. Well-posedness results for non-autonomous dissipative complementarity systems. [Research Report] RR-5931, INRIA. 2006. ⟨inria-00079220v3⟩
Share
Metrics
Record views
388
Files downloads
327
