Well-posedness results for non-autonomous dissipative complementarity systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
This paper deals with the well-posedness of a class of nonsmooth dynamical systems: dissipative complementarity systems. Both the linear and the nonlinear cases are treated, and the systems are non-autonomous. The dissipativity property is used to perform a particular change of state vector which allows one to transform the dynamics into a perturbed Moreau's sweeping process. As an example an electrical circuit with ideal diodes is presented.
RR-5929.pdf (338.83 Ko) Télécharger le fichier
inria-00079220 , version 1 (09-06-2006)
inria-00079220 , version 2 (12-06-2006)
inria-00079220 , version 3 (13-06-2006)
  • HAL Id : inria-00079220 , version 2
Bernard Brogliato, Lionel Thibault. Well-posedness results for non-autonomous dissipative complementarity systems. [Research Report] RR-5929, 2006. ⟨inria-00079220v2⟩
Collections
INRIA-RRRT
158 Consultations
216 Téléchargements
