Copy protection for DVD video, special issue on identification and protection of multimedia information, pp.1267-1276, 1999. ,
DOI : 10.1109/5.771077
Jaap Haitsma, Digital watermarking for DVD video copy protection, Signal Processing Magazine, vol.17, issue.5 ,
Resolving rightful ownerships with invisible watermarking techniques: limitations, attacks, and implications, IEEE Journal on Selected Areas in Communications, vol.16, issue.4, pp.573-87, 1998. ,
DOI : 10.1109/49.668979
Automatic Detection of a Watermarked Document Using a Private Key, 4th Int, p.p. electronic version, 2001. ,
DOI : 10.1007/3-540-45496-9_19
Cryptography meets watermarking: Detecting watermarks with minimal or zero knowledge disclosure, Proc. of European Signal Processing Conference, 2002. ,
DOI : 10.1007/s00530-003-0098-z
Considerations on watermarking seccurity, Proc of the IEEE Multimedia Signal Processing MMSP'01 workshop, pp.201-206, 2001. ,
DOI : 10.1109/mmsp.2001.962734
Use of watermarking techniques for copy protection, Ecole Nationale Supérieure des Télécommunications, 2002. ,
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, pp.644-54, 1976. ,
DOI : 10.1109/TIT.1976.1055638
Watermarking as communications with side information, Proc. IEEE, pp.1127-1141, 1999. ,
DOI : 10.1109/5.771068
Some general methods for tampering with watermarks, IEEE Journal on Selected Areas in Communications, vol.16, issue.4, pp.587-93, 1998. ,
DOI : 10.1109/49.668980
URL : http://buffy.eecs.berkeley.edu/~linnartz/articles/jsacfinal.ps
The watermark template attack, Security and Watermarking of Multimedia Contents III, SPIE Proceedings, 2001. ,
Collusion-secure fingerprinting for digital data, IEEE Transactions on Information Theory, vol.44, issue.5, pp.1897-1905, 1998. ,
DOI : 10.1109/18.705568
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.31.6638
<title>Combining digital watermarks and collusion-secure fingerprints for digital images</title>, Security and Watermarking of Multimedia Contents, 1999. ,
DOI : 10.1117/12.344702
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.479
Joint coding and embedding for collusionresistant fingerprinting, Proc. European Signal Processing Conf, 2002. ,
Communication Theory of Secrecy Systems*, Bell System Technical Journal, vol.28, issue.4, pp.656-715, 1949. ,
DOI : 10.1002/j.1538-7305.1949.tb00928.x
Removing spatial spread spectrum watermarks by non-linear filtering, Proc. of 9th European Signal Processing Conference, 1998. ,
DVD privacy: It can be done ,
Lessons learned from SDMI, 2001 IEEE Fourth Workshop on Multimedia Signal Processing (Cat. No.01TH8564), 2001. ,
DOI : 10.1109/MMSP.2001.962736
The code book, Fourth Estate Limited, 1999. ,
Secure spread spectrum watermarking for multimedia, IEEE Transactions on Image Processing, vol.6, issue.12, pp.1673-1687, 1997. ,
DOI : 10.1109/83.650120
Fast Robust Template Matching for Affine Resistant Image Watermarks, Proc. of the third Int. Workshop on Information Hiding, pp.199-210, 1999. ,
DOI : 10.1007/10719724_15
Pun, Rotation, scale and translation invariant spread spectrum digital image watermarking, Signal Processing, Special issue on copyrigth protection and control, vol.66, issue.3, pp.303-320, 1998. ,
A new video-object watermarking scheme robust to object manipulation, Proc. of Int. Conf. on Image Processing, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00166583
Watermarking schemes evaluation, IEEE Signal Processing Magazine, vol.17, issue.5, pp.58-64, 2000. ,
DOI : 10.1109/79.879339
Second Generation Benchmarking and Application Oriented Evaluation, Fourth workshop on information hiding, 2001. ,
DOI : 10.1007/3-540-45496-9_25
Nikolaidis, I.Pitas, A benchmarking protocol for watermarking methods, Proc. 2001 IEEE Int. Conf. on Image Processing -ICIP'01, pp.1023-1026, 2001. ,
Blind pattern matching attack on audio watermarking systems, Proc. of the IEEE Int. Conf. on Acoustic, Speech and Signal Processing, 2002. ,
Toward generic image dewatermarking?, Proceedings. International Conference on Image Processing, pp.633-636, 2002. ,
DOI : 10.1109/ICIP.2002.1039050
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.554
A Stochastic Approach to Content Adaptive Digital Image Watermarking, Third workshop on information hiding, 1999. ,
DOI : 10.1007/10719724_16
Analysis of digital watermarks subjected to optimum linear filtering and additive noise, Signal Processing, vol.81, issue.6, pp.81-1141, 2001. ,
DOI : 10.1016/S0165-1684(01)00038-X
Perceptual watermarking of non i.i.d. signals based on wide spread spectrum using side information, Proc. of IEEE Int. Conf. on Image Processing, 2002. ,
A security risk for publicly available watermark detectors, Benelux Information Theory Symposium, 1998. ,
Is asymmetric watermarking necessary or sufficient?, Proc. European Signal Processing Conference -EUSIPCO 2002, 2002. ,
An asymmetric watermarking method, accepted to the special issue on signal processing for data hiding in digital media & secure content delivery, IEEE Trans. on Signal Processing, 2003. ,
Just Another N-order side-Informed Scheme, Proc. of Int. Conf. on Image Processing ICIP'02, 2002. ,
DOI : 10.1109/icip.2002.1039910
URL : https://hal.archives-ouvertes.fr/inria-00080826
Secure detection of public watermarks with fractal decision boundaries, Proc. European Signal Processing Conference - EUSIPCO 2002, 2002. ,
Secret key watermarking with changing keys, Proceedings 2000 International Conference on Image Processing (Cat. No.00CH37101), pp.427-429, 2000. ,
DOI : 10.1109/ICIP.2000.900986
An Information-Theoretic Model for Steganography, Proc. of the second Int. Workshop on Information Hiding, pp.306-318, 1998. ,
DOI : 10.1007/3-540-49380-8_21
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.9769
An infomation-theoritic approach to steganography and watermarking, Proc. of the third Int. Workshop on Information Hiding, pp.1-17, 1999. ,
Unified approach of asymmetric watermarking schemes, Security and Watermarking of Multimedia Contents III, SPIE, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00080814
