Improving Accuracy in Available Bandwidth Estimation for 802.11-based Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this paper, we propose an accurate method to evaluate the available bandwidth in IEEE 802.11-based ad hoc networks. This method is based on a mechanism to predict the synchronisation of ilde periods and an estimation of collision probability on wireless link. We evaluate our solution on different scenarios. We also provide a comparison with different QoS routing protocols, BRuIT, AAC and QoS-AODV, based on different available bandwidth estimation techniques.
RR.pdf (628.88 Ko) Télécharger le fichier
inria-00080939 , version 1 (21-06-2006)
inria-00080939 , version 2 (23-06-2006)
  • HAL Id : inria-00080939 , version 1
Cheikh Sarr, Claude Chaudet, Guillaume Chelius, Isabelle Guérin Lassous. Improving Accuracy in Available Bandwidth Estimation for 802.11-based Ad Hoc Networks. [Research Report] 2006, pp.23. ⟨inria-00080939v1⟩
129 Consultations
624 Téléchargements
