The Genetic Code Degeneration I: Rules Governing the Code Degeneration and the Spatial Organization of the Codon Informative Properties. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
the present work is devoted to describe a set of rules explaining the discriminating versus non-discriminating behavior of the di-basic stages and to characterize the role of each base in determining such a behavior. Bases are analyze as dual entities characterized by its chemical type and the number of H bonds involved in the codon-anticodon interaction. A codon is characterized as an asymmetric informative entity whose global informative capacity results from the spatially organized combinatory of the 6 proper-ties assigned by the 3 bases.
RR_INRIA_Rapacioli_Rofman_Flores.pdf (231.82 Ko) Télécharger le fichier
inria-00081981 , version 1 (26-06-2006)
inria-00081981 , version 2 (04-07-2006)
  • HAL Id : inria-00081981 , version 1
Edmundo Rofman, Melina Rapacioli, Vladimir Flores. The Genetic Code Degeneration I: Rules Governing the Code Degeneration and the Spatial Organization of the Codon Informative Properties.. [Research Report] 2006. ⟨inria-00081981v1⟩
95 Consultations
428 Téléchargements
