Abstract : the present work is devoted to describe a set of rules explaining the discriminating versus non-discriminating behavior of the di-basic stages and to characterize the role of each base in determining such a behavior. Bases are analyze as dual entities characterized by its chemical type and the number of H bonds involved in the codon-anticodon interaction. A codon is characterized as an asymmetric informative entity whose global informative capacity results from the spatially organized combinatory of the 6 proper-ties assigned by the 3 bases.
https://hal.inria.fr/inria-00081981 Contributor : Rapport de Recherche InriaConnect in order to contact the contributor Submitted on : Tuesday, July 4, 2006 - 2:54:25 PM Last modification on : Thursday, February 3, 2022 - 11:18:07 AM Long-term archiving on: : Monday, September 20, 2010 - 4:18:44 PM
Edmundo Rofman, Melina Rapacioli, Vladimir Flores. The Genetic Code Degeneration I: Rules Governing the Code Degeneration and the Spatial Organization of the Codon Informative Properties.. [Research Report] RR-5938, INRIA. 2006. ⟨inria-00081981v2⟩
