Higher-order dependency pairs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Arts and Giesl proved that the termination of a first-order rewrite system can be reduced to the study of its ``dependency pairs''. We extend these results to rewrite systems on simply typed lambda-terms by using Tait's computability technique.
main.pdf (116.82 Ko) Télécharger le fichier
inria-00084821 , version 1 (05-09-2006)
inria-00084821 , version 2 (11-09-2006)
inria-00084821 , version 3 (23-04-2018)
  • HAL Id : inria-00084821 , version 1
Frédéric Blanqui. Higher-order dependency pairs. Eighth International Workshop on Termination - WST 2006, Aug 2006, Seattle, Washington/USA. ⟨inria-00084821v1⟩
109 Consultations
52 Téléchargements
