The Statistics Of Spikes Trains For Some Simple Types Of Neuron Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Faugeras
Théodore Papadopoulo
Denis Talay
  • Fonction : Auteur
  • PersonId : 833429
Mireille Bossy
This paper describes some preliminary results of a research program for characterizing the statistics of spikes trains for a variety of commonly used neuron models in the presence of stochastic noise and deterministic input. The main angle of attack of the problem is through the use of stochastic calculus and ways of representing (local)martingales as Brownianmotions by changing the time scale
RR.pdf (179.67 Ko) Télécharger le fichier
inria-00084905 , version 1 (13-07-2006)
inria-00084905 , version 2 (19-07-2006)
inria-00084905 , version 3 (18-10-2007)
inria-00084905 , version 4 (24-10-2007)
  • HAL Id : inria-00084905 , version 4
Olivier Faugeras, Théodore Papadopoulo, Jonathan Touboul, Denis Talay, Etienne Tanré, et al.. The Statistics Of Spikes Trains For Some Simple Types Of Neuron Models. [Research Report] RR-5950, INRIA. 2007, pp.15. ⟨inria-00084905v4⟩
446 Consultations
249 Téléchargements
