Circular Choosability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we study the notion of circular choosability recently introduced by Mohar and Zhu. First, we provide a negative answer to a question of Zhu about circular cliques. We next prove that, for every graph G, cch(G) = O( ch(G) + ln |V(G)| ). We investigate a generalisation of circular choosability, circular f-choosability, when f is a function of the degrees. We also consider the circular choice number of planar graphs. Mohar asked for the value of tau := sup{ cch(G) : G is planar }, and we prove that 6 <= tau <= 8, thereby providing a negative answer to another question of Mohar. Finally, we study the circular choice number of planar and outerplanar graphs with prescribed girth, and graphs with bounded density.
RR-5957.pdf (414.25 Ko) Télécharger le fichier
inria-00086981 , version 1 (20-07-2006)
inria-00086981 , version 2 (01-08-2006)
  • HAL Id : inria-00086981 , version 2
Frédéric Havet, Ross Kang, Tobias Müller, Jean-Sébastien Sereni. Circular Choosability. [Research Report] RR-5957, INRIA. 2007, pp.33. ⟨inria-00086981v2⟩
230 Consultations
107 Téléchargements
