Fast computation of the leastcore and prenucleolus of cooperative games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The computation of leastcore and prenucleolus is an efficient way of allocating a common resource among $N$ players. It has, however, the drawback being a linear programming problem with $2^N-2$ constraints. In this paper we show how, in the case of convex production games, generate constraints by solving small size linear programming problems, with both continuous and integer variables. The approach is extended to games with symmetries (identical players), and to games with partially continuous coalitions. We also study the computation of prenucleolus, and display encouraging numerical results.
RR-5956.pdf (265.77 Ko) Télécharger le fichier
inria-00087029 , version 1 (21-07-2006)
inria-00087029 , version 2 (01-08-2006)
  • HAL Id : inria-00087029 , version 2
J. Frederic Bonnans, Matthieu Andre. Fast computation of the leastcore and prenucleolus of cooperative games. [Research Report] RR-5956, INRIA. 2006, pp.15. ⟨inria-00087029v2⟩
102 Consultations
278 Téléchargements
