Learning n-ary Node Selecting Tree Transducers from Completely Annotated Examples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present the first algorithm for learning n-ary node selection queries in trees from completely annotated examples by methods of grammatical inference. We propose to represent n-ary queries by deterministic n-ary node selecting tree transducers (NSTTs), that are known to capture the class of MSO-definable n-ary queries. Despite of this highly expressive, we show that n-aryy queries, selecting a polynomially bounded number of tuples per tree, represented by deterministic NSTTs can be learned from polynomial time and data while allowing for efficient enumeration of query answers. An application to wrapper induction in Web information extraction yields encouraging results.
0.pdf (219.03 Ko) Télécharger le fichier
inria-00088077 , version 1 (29-07-2006)
inria-00088077 , version 2 (13-08-2006)
  • HAL Id : inria-00088077 , version 2
Aurélien Lemay, Joachim Niehren, Rémi Gilleron. Learning n-ary Node Selecting Tree Transducers from Completely Annotated Examples. 8th International Colloquium on Grammatical Inference, Sep 2006, Tokyo, Japan. pp.253-267. ⟨inria-00088077v2⟩
279 Consultations
325 Téléchargements
