Reports
A Generic Lazy Evaluation Scheme for Exact Geometric Computations
Sylvain Pion 1 Andreas Fabri 1
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We present a generic C++ design to perform efficient and exact geometric computations using lazy evaluations. Exact geometric computations are critical for the robustness of geometric algorithms. Their efficiency is also critical for most applications, hence the need for delaying the exact computations at run time until they are actually needed. Our approach is generic and extensible in the sense that it is possible to make it a library which users can extend to their own geometric objects or primitives. It involves techniques such as generic functor adaptors, dynamic polymorphism, reference counting for the management of directed acyclic graphs and exception handling for detecting cases where exact computations are needed. It also relies on multiple precision arithmetic as well as interval arithmetic. We apply our approach to the whole geometric kernel of CGAL.
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00089229
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, August 18, 2006 - 4:56:38 PM
Last modification on : Friday, February 4, 2022 - 3:16:09 AM
Long-term archiving on: : Monday, September 20, 2010 - 4:47:41 PM
Identifiers
Collections
Citation
Sylvain Pion, Andreas Fabri. A Generic Lazy Evaluation Scheme for Exact Geometric Computations. [Research Report] RR-5966, INRIA. 2006, pp.23. ⟨inria-00089229v2⟩
Share
Metrics
Record views
117
Files downloads
96
