-resilient asynchronous computations, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.91-100, 1993. ,
DOI : 10.1145/167088.167119
URL : https://hal.archives-ouvertes.fr/hal-00896459
Unreliable failure detectors for reliable distributed systems, Journal of the ACM, vol.43, issue.2, pp.225-267, 1996. ,
DOI : 10.1145/226643.226647
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
The Weakest Failure Detectors to Boost Obstruction-Freedom, Proc. 20th Symposium on Distributed Computing (DISC'06), pp.376-390, 2006. ,
The information structure of indulgent consensus, IEEE Transactions on Computers, vol.53, issue.4, pp.453-466, 2004. ,
DOI : 10.1109/TC.2004.1268403
The Alpha of Indulgent Consensus, The Computer Journal, vol.50, issue.1, 2006. ,
DOI : 10.1093/comjnl/bxl046
Wait-free synchronization, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.124-149, 1991. ,
DOI : 10.1145/114005.102808
Tight Bounds for k-Set Agreement with Limited Scope Accuracy Failure Detectors, Distributed Computing, pp.157-166, 2005. ,
The topological structure of asynchronous computability, Journal of the ACM, vol.46, issue.6, pp.858-923, 1999. ,
DOI : 10.1145/331524.331529
The part-time parliament, ACM Transactions on Computer Systems, vol.16, issue.2, pp.133-169, 1998. ,
DOI : 10.1145/279227.279229
Memory requirements for agreement among unreliable asynchronous processes Advances in Computing research, pp.163-183, 1987. ,
Irreducibility and additivity of set agreement-oriented failure detector classes, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, 2006. ,
DOI : 10.1145/1146381.1146406
k-set agreement with limited accuracy failure detectors, Proceedings of the nineteenth annual ACM symposium on Principles of distributed computing , PODC '00, pp.143-152, 2000. ,
DOI : 10.1145/343477.343536
LEADER-BASED CONSENSUS, Parallel Processing Letters, vol.11, issue.01, pp.95-107, 2001. ,
DOI : 10.1142/S0129626401000452
Exploring Gafni's reduction land: from k to wait-free adaptive (2p ,
Failure Detectors and the Wait-free Hierarchy, Proc. 14th ACM Symp. on Principles of Distributed Computing (PODC'95, pp.100-109, 1995. ,
-set agreement is impossible, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.1449-1483, 2000. ,
DOI : 10.1145/167088.167122
URL : https://hal.archives-ouvertes.fr/hal-00192526
Structured derivations of consensus algorithms for failure detectors, Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.297-308, 1998. ,
DOI : 10.1145/277697.277755
