Lagrangian Approaches for a class of Matching Problems in Computational Biology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
This paper presents efficient algorithms for solving the problem of aligning a protein structure template to a query amino-acid sequence, known as protein threading problem. We consider the problem as a special case of graph matching problem. We give formal graph and integer programming models of the problem. After studying the properties of these models, we propose two kinds of Lagrangian relaxation for solving them. We present experimental results on real life instances showing the efficiency of our approaches.
RR-5973.pdf (536.85 Ko) Télécharger le fichier
inria-00090635 , version 1 (01-09-2006)
inria-00090635 , version 2 (07-09-2006)
Nicola Yanev, Rumen Andonov, Philippe Veber, Stefan Balev. Lagrangian Approaches for a class of Matching Problems in Computational Biology. [Research Report] RR-5973, INRIA. 2006. ⟨inria-00090635v2⟩
203 Consultations
115 Téléchargements
