Heterogeneous multi-cluster networking with the Madeleine III communication library, Proceedings 16th International Parallel and Distributed Processing Symposium, 2002. ,
DOI : 10.1109/IPDPS.2002.1015658
LAM: An Open Cluster Environment for MPI, Proceedings of Supercomputing Symposium, pp.379-386, 1994. ,
Distributed computing in a heterogenous computing environment. Recent advances in Parallel Virtual Machine and Message Passing Interface, pp.180-188, 1998. ,
MPICH/MADIII : a cluster of clusters enabled MPI implementation, CCGrid 2003. 3rd IEEE/ACM International Symposium on Cluster Computing and the Grid, 2003. Proceedings., 2003. ,
DOI : 10.1109/CCGRID.2003.1199349
URL : https://hal.archives-ouvertes.fr/hal-00344362
Grid'5000: A large scale, reconfigurable , controlable and monitorable grid platform, Proceedings of the 6th IEEE/ACM International Workshop on Grid Computing, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000284
The Grid: Blueprint for a New Computing Infrastructure, MorganKaufmann, 1998. ,
Globus: a Metacomputing Infrastructure Toolkit, International Journal of High Performance Computing Applications, vol.11, issue.2, pp.115-128, 1997. ,
DOI : 10.1177/109434209701100205
Open MPI: Goals, Concept, and Design of a Next Generation MPI Implementation, Proceedings, 11th European PVM/MPI Users' Group Meeting, pp.97-104, 2004. ,
DOI : 10.1007/978-3-540-30218-6_19
HARNESS and fault tolerant MPI, Parallel Computing, vol.27, issue.11, pp.1479-1496, 2001. ,
The MPI communication library: its design and a portable implementation, Proceedings of Scalable Parallel Libraries Conference, pp.160-165, 1994. ,
DOI : 10.1109/SPLC.1993.365571
A high-performance, portable implementation of the MPI message passing interface standard, Parallel Computing, vol.22, issue.6, pp.789-828, 1996. ,
DOI : 10.1016/0167-8191(96)00024-5
Myrinet Express (MX) : A High Performance, Low-Level, Message- Passing Interface for Myrinet, 2006. ,
High Performance RDMA-Based MPI Implementation over Infiniband, The International Journal of Parallel Programming, vol.32, issue.3, 2004. ,
Clusters interconnects : The whole shebang. ClusterMonkey, 2006. ,
TCP adaptation for MPI on long-and-fat networks, Cluster, 2005. ,
A message passing interface library for inhomogeneous coupled clusters, IPDPS, Workshop for Communication Architecture in Clusters, 2003. ,
Communications à hautes performances portables en environnements hiérarchiques, hétérogènes et dynamiques, Thèse de doctorat, 2005. ,
MPICH-G2: A Grid-Enabled Implementation of the Message Passing Interface, Journal of Parallel and Distributed Computing, pp.551-563, 2003. ,
Communicating efficiently on cluster based grids with MPICH-VMI, 2004 IEEE International Conference on Cluster Computing (IEEE Cat. No.04EX935), 2004. ,
DOI : 10.1109/CLUSTR.2004.1392598
Parallel virtual machine ,
PM2 : Parallel multithreaded machine, a computing environment for distributed architectures, Parallel Computing (Par'Co 95), pp.279-285, 1995. ,
A Network-Failure- Tolerant Message-Passing System For Terascale Clusters, ICS02, 2002. ,
