Abstract : The Semantic Web envisions a world-wide distributed architecture where computational resources will easily inter-operate to coordinate complex tasks such as query answering. Semantic marking up of web resources using ontologies is expected to provide the necessary glue for making this vision work. Using ontology languages, (communities of) users will build their own ontologies in order to describe their own data. Adding semantic mappings between those ontologies, in order to semantically relate the data to share, gives rise to the Semantic Web: data on the web that are annotated by ontologies networked together by mappings. In this vision, the Semantic Web is a huge semantic peer data management system. In this paper, we describe the SomeRDFS peer data management systems that promote a "simple is beautiful" vision of the Semantic Web based on data annotated by RDFS ontologies.
