A Rational Function Decomposition Algorithm by Near-separated Polynomials, Journal of Symbolic Computation, vol.19, issue.6, pp.527-544, 1995. ,
DOI : 10.1006/jsco.1995.1030
The number of points on an elliptic curve modulo a prime (II) ,
Composing Power Series Over a Finite Ring in Essentially Linear Time, Journal of Symbolic Computation, vol.26, issue.3, pp.339-341, 1998. ,
DOI : 10.1006/jsco.1998.0216
Removing redundancy in high-precision Newton iteration, 2000. ,
Elliptic curves in cryptography, 1999. ,
DOI : 10.1017/CBO9781107360211
MULTIPLE-PRECISION ZERO-FINDING METHODS AND THE COMPLEXITY OF ELEMENTARY FUNCTION EVALUATION, Analytic computational complexity, pp.151-176 ,
DOI : 10.1016/B978-0-12-697560-4.50014-9
Fast solution of toeplitz systems of equations and computation of Pad?? approximants, Journal of Algorithms, vol.1, issue.3, pp.259-295, 1980. ,
DOI : 10.1016/0196-6774(80)90013-9
Fast Algorithms for Manipulating Formal Power Series, Journal of the ACM, vol.25, issue.4, pp.581-595, 1978. ,
DOI : 10.1145/322092.322099
Fast Point Multiplication on Elliptic Curves through Isogenies, Lecture Notes in Computer Science, vol.2643, pp.43-50, 2003. ,
DOI : 10.1007/3-540-44828-4_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.6968
On fast multiplication of polynomials over arbitrary algebras, Acta Informatica, vol.7, issue.7, pp.693-701, 1991. ,
DOI : 10.1007/BF01178683
Enumeration of rational points on elliptic curves over finite fields. Draft, 1991. ,
On the minimum computation time of functions, Transactions of the American Mathematical Society, vol.142, 1966. ,
DOI : 10.1090/S0002-9947-1969-0249212-8
Quelques calculs en théorie des nombres, Thèse, 1994. ,
Computing l-isogenies using the p-torsion, Proceedings of the Second International Symposium , ANTS-II, pp.59-65, 1996. ,
DOI : 10.1007/3-540-61581-4_41
Isomorphisms between Artin-Schreier towers, Mathematics of Computation, vol.69, issue.232, pp.1625-1631, 2000. ,
DOI : 10.1090/S0025-5718-00-01193-5
Isogeny cycles and the Schoof-Elkies- Atkin algorithm, 1996. ,
Action of Modular Correspondences around CM Points, Algorithmic Number Theory Proceedings of the 5th International Symposium, ANTS-V, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
Schoof's algorithm and isogeny cycles, Algorithmic Number Theory 1st Algorithmic Number Theory Symposium -Cornell University, pp.43-58, 1994. ,
DOI : 10.1007/3-540-58691-1_42
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.46.9220
Isogénie entre courbes elliptiques, Utilitas Mathematica, vol.55, pp.123-127, 1999. ,
Efficient Scalar Multiplication by Isogeny Decompositions, Cryptology ePrint Archive Report, vol.420, 2005. ,
DOI : 10.1007/11745853_13
Elliptic and modular curves over finite fields and related computational issues, Computational Perspectives on Number Theory: Proceedings of a Conference in Honor of A. O. L. Atkin, pp.21-76, 1998. ,
DOI : 10.1090/amsip/007/03
Isogeny Volcanoes and the SEA Algorithm, Algorithmic Number Theory Proceedings of the 5th International Symposium, ANTS-V, pp.276-291, 2002. ,
DOI : 10.1007/3-540-45455-1_23
Abstract, LMS Journal of Computation and Mathematics, vol.549, pp.118-138, 1999. ,
DOI : 10.2307/2006496
Extending the GHS Weil Descent Attack, Advances in cryptology?EUROCRYPT 2002, pp.29-44, 2002. ,
DOI : 10.1007/3-540-46035-7_3
Modern computer algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
The hasse invariant andp-division points of an elliptic curve, Archiv der Mathematik, vol.145, issue.1, pp.148-158, 1976. ,
DOI : 10.1007/BF01224654
A practical implementation of two rational function decomposition algorithms, Papers from the international symposium on Symbolic and algebraic computation , ISSAC '92, pp.152-157, 1992. ,
DOI : 10.1145/143242.143298
The Middle Product Algorithm I, Applicable Algebra in Engineering, Communication and Computing, vol.14, issue.6, pp.415-438, 2004. ,
DOI : 10.1007/s00200-003-0144-2
URL : https://hal.archives-ouvertes.fr/inria-00071921
Do All Elliptic Curves of the Same Order Have the Same Difficulty of Discrete Log?, Advances in Cryptology ? ASIACRYPT 2005 11th International Conference on the Theory and Application of Cryptology and Information Security, pp.21-40, 2005. ,
DOI : 10.1007/11593447_2
Counting points on elliptic curves in medium characteristic, Cryptology ePrint Archive Report, vol.176, 2006. ,
Subquadratic-time factoring of polynomials over finite fields, Mathematics of Computation, vol.67, issue.223, pp.1179-1197, 1998. ,
DOI : 10.1090/S0025-5718-98-00944-2
Counting points on hyperelliptic curves using Monsky-Washnitzer cohomology, Journal of the Ramanujan Mathematical Society, vol.16, issue.4, pp.323-338, 2001. ,
On computing reciprocals of power series, Numerische Mathematik, vol.264, issue.5, pp.341-348, 1974. ,
DOI : 10.1007/BF01436917
Computing isogenies in $$\mathbb{F}_{2^n } $$, Proceedings of the Second International Symposium, ANTS-II, pp.197-212, 1996. ,
DOI : 10.1007/3-540-61581-4_55
Algorithmique des courbes elliptiques dans les corps finis, Thèse, ´ Ecole polytechnique, 1997. ,
URL : https://hal.archives-ouvertes.fr/tel-01101949
Computing isogenies between elliptic curves over $F_{p^n}$ using Couveignes's algorithm, Mathematics of Computation, vol.69, issue.229, pp.351-370, 2000. ,
DOI : 10.1090/S0025-5718-99-01081-9
Calcul du nombre de points sur une courbe elliptique dans un corps fini : aspects algorithmiques, Journal de Th??orie des Nombres de Bordeaux, vol.7, issue.1, pp.255-282, 1995. ,
DOI : 10.5802/jtnb.143
Ein Algorithmus zur Bestimmung der Punktanzahl elliptischer Kurvenüber Kurven¨Kurvenüber endlichen Körpern der Charakteristik größer drei, 1995. ,
Public-key cryptosystem based on isogenies, Cryptology ePrint Archive Report, vol.145, 2006. ,
The canonical lift of an ordinary elliptic curve over a finite field and its point counting, Journal of the Ramanujan Mathematical Society, vol.15, pp.247-270, 2000. ,
The fundamental theorem of algebra in terms of computational complexity, 1982. ,
Fast multiplication of large numbers, Computing, vol.150, issue.3-4, pp.281-292, 1971. ,
DOI : 10.1007/BF02242355
Counting points on elliptic curves over finite fields, Journal de Th??orie des Nombres de Bordeaux, vol.7, issue.1, pp.219-254, 1995. ,
DOI : 10.5802/jtnb.142
A New Polynomial Factorization Algorithm and its Implementation, Journal of Symbolic Computation, vol.20, issue.4, pp.363-397, 1995. ,
DOI : 10.1006/jsco.1995.1055
The Number Theory Library, 1996. ,
Ein Algorithmus f??r Potenzreihendivision, Computing, vol.10, issue.1-2, pp.153-156, 1972. ,
DOI : 10.1007/BF02242389
The arithmetic of elliptic curves, Graduate Texts in Mathematics, vol.106, 1986. ,
Advanced topics in the arithmetic of elliptic curves, Graduate Texts in Mathematics, vol.151, 1994. ,
DOI : 10.1007/978-1-4612-0851-8
An Analysis of Goubin???s Refined Power Analysis Attack, Cryptographic Hardware and Embedded Systems ? CHES 2003, pp.281-290, 2003. ,
DOI : 10.1007/978-3-540-45238-6_23
Class-numbers of complex quadratic fields Modular functions of one variable I, Proceedings International Summer School University of, pp.155-174, 1972. ,
An Elliptic Curve Trapdoor System, Journal of Cryptology, vol.19, issue.1, pp.115-133, 2006. ,
DOI : 10.1007/s00145-004-0328-3
Isogénies entre courbes elliptiques. Comptes-Rendus de l'Académie des Sciences, Série I, pp.238-241, 1971. ,
