Young integrals and SPDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Potential Analysis Année : 2006
In this note, we study the non-linear evolution problem dY_t = -A Y_t dt + B(Y_t) dX_t, where X is a \gamma-Hölder continuous function of the time parameter, with values in a distribution space, and -A the generator of an analytical semigroup. Then, we will give some sharp conditions on X in order to solve the above equation in a function space, first in the linear case (for any value of $\gamma$ in (0,1)), and then when B satisfies some Lipschitz type conditions (for \gamma>1/2). The solution of the evolution problem will be understood in the mild sense, and the integrals involved in that definition will be of Young type.
gubinelli-lejay-tindel.pdf (300.92 Ko) Télécharger le fichier
inria-00092425 , version 1 (10-09-2006)
  • HAL Id : inria-00092425 , version 1
Massimiliano Gubinelli, Antoine Lejay, Samy Tindel. Young integrals and SPDEs. Potential Analysis, 2006, 25 (4), pp.307-326. ⟨inria-00092425⟩
188 Consultations
1237 Téléchargements
