Non-negative solutions of linear parabolic equation, Ann. Scuola Norm. Sup. Pisa, vol.22, issue.5, pp.607-693, 1968. ,
Extending the Wong-Zakai theorem to reversible Markov processes, Journal of the European Mathematical Society, vol.4, issue.3, pp.237-269, 2002. ,
DOI : 10.1007/s100970200040
Integration of paths, geometric invariants and a generalized Baker-Hausdorff formula, Ann. of Math, vol.65, issue.2, pp.163-178, 1957. ,
Semi-martingales and rough paths theory Stochastic analysis, rough path analysis and fractional Brownian motions. Probab. Theory Related Fields, 13 [CS99] F. Coquet and L. SS lomi´nskilomi´nski. On the convergence of Dirichlet processes. Bernoulli, pp.23-761, 1999. ,
DOI : 10.1007/s004400100158
Formule d'Itô pour des diffusions uniformément elliptiques et processus de Dirichlet. Potential Anal [Föl81a] H. Föllmer. Calcul d'Itô sans probabilités, Séminaire de Probabilités, XV, pp.7-10, 2004. ,
Dirichlet processes, Stochastic integrals (Proc. Sympos, pp.476-478, 1980. ,
Generalized integration and stochastic ODEs, Dirichlet Forms and Symmetric Markov Process. De Gruyter, pp.270-292, 1994. ,
A note on the notion of geometric rough paths, Probability Theory and Related Fields, vol.3, issue.3, 2006. ,
DOI : 10.1007/s00440-005-0487-7
Stochastic area for Brownian motion on the Sierpinski gasket, The Annals of Probability, vol.26, issue.1, pp.132-148, 1998. ,
DOI : 10.1214/aop/1022855414
Stochastic Differential Equations and Diffusion Processes, Stochastic flows and stochastic differential equations, pp.29-29, 1989. ,
Méthodes probabilistes pour l'homogénéisation des opérateurs sous forme-divergence : cas linéaires et semi-linéaires, 2000. ,
An introduction to rough paths, Séminaire de probabilités, XXXVII, pp.1-59, 2003. ,
A Probabilistic Representation of the Solution of some Quasi-Linear PDE with a Divergence-Form Operator Application to Existence of Weak Solutions of FBSDE, Lej03c] A. Lejay. Stochastic Differential Equations driven by processes generated by divergence form operators II: Convergence results, pp.145-176, 2004. ,
On the Importance of the Lévy Area for Systems Controlled by Converging Stochastic Processes. Application to Homogenization The Theta Foundation, pp.18-30, 2003. ,
Lévy area of Wiener processes in Banach spaces The limits of stochastic integrals of differential forms, Ann. Probab. Qian. System Control and Rough Paths. Oxford Mathematical Monographs Ann. Probab, vol.30, issue.271, pp.546-578, 1999. ,
Differential equations driven by rough signals, LV06] A. Lejay and N. Victoir. On (p, q)-rough paths, pp.215-310, 1998. ,
Stochastic differential equations and models of random processes, Proceedings of the Sixth Berkeley Symposium on Mathematical Statistics and Probability (Univ. California III: Probability theoryRoz96] A. Rozkosz. Stochastic Representation of Diffusions Corresponding to Divergence Form Operators. Stochastic Process, pp.263-294, 1970. ,
On Dirichlet processes associated with second order divergence form operators, Potential Anal, vol.14, issue.2 7, pp.123-148, 2001. ,
Extended convergence of dirichlet processes, Stochastics An International Journal of Probability and Stochastic Processes, vol.65, issue.1, pp.1-2, 1998. ,
DOI : 10.1080/17442509808834174
Continuous Martingales and Brownian Motion, 1990. ,
DOI : 10.1007/978-3-662-06400-9
A pathwise view of solutions of stochastic differential equations, 1993. ,
Diffusion Semigroups Corresponding to Uniformly Elliptic Divergence Form Operator, Séminaire de Probabilités XXII, pp.316-347, 1988. ,
Path-wise solutions of SDE's driven by Lévy processes, Rev. Mat. Iberoamericana, vol.17, issue.2 2, pp.295-330, 2002. ,
On the Convergence of Ordinary Integrals to Stochastic Integrals, The Annals of Mathematical Statistics, vol.36, issue.5, pp.1560-1564, 1965. ,
DOI : 10.1214/aoms/1177699916
