Simulating a diffusion on a graph. Application to reservoir engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2003
We develop a simple Monte Carlo method to compute the position at a given time of a diffusion on a graph, with constant speed on each edge. This method is exact, and we claim it could be used for simulating the position of a particle in a fissured media. Besides, we advocate that the notion of diffusions on graphs could be useful to understand the behavior of one-dimensional diffusions whose infinitesimal generator has piecewise constant coefficients.
lejay-mcma2003.pdf (294.01 Ko) Télécharger le fichier
inria-00092428 , version 1 (10-09-2006)
  • HAL Id : inria-00092428 , version 1
Antoine Lejay. Simulating a diffusion on a graph. Application to reservoir engineering. Monte Carlo Methods and Applications, 2003, 9 (3), pp.241-255. ⟨inria-00092428⟩
108 Consultations
646 Téléchargements
