A VFRoe scheme for 1D shallow water flows : wetting and drying simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
A finite-volume method for the one-dimensional shallow-water equations including topographic source terms is presented. Exploiting an original idea by Leroux, the system of partial-differential equations is completed by a trivial equation for the bathymetry. By applying a change of variable, the system is given a celerity-speed formulation, and linearized. As a result, an approximate Riemann solver preserving the positivity of the celerity can be constructed, permitting wetting and drying flow simulations to be performed. Finally, the simulation of numerical test cases is presented.
saintvenant1D.pdf (385.37 Ko) Télécharger le fichier
inria-00095492 , version 1 (18-09-2006)
inria-00095492 , version 2 (30-11-2006)
inria-00095492 , version 3 (06-12-2006)
Abdou Wahidi Bello. A VFRoe scheme for 1D shallow water flows : wetting and drying simulation. [Rapport de recherche] 2006, pp.24. ⟨inria-00095492v1⟩
483 Consultations
219 Téléchargements
