Generalized resultants over unirational algebraic varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2000
In this paper, we propose a new method, based on Bezoutian matrices, for computing a nontrivial multiple of the resultant over a projective variety X, which is described on an open subset by a parameterization. This construction, which generalizes the classical and toric one, also applies for instance to blowing up varieties and to residual intersection problems. We recall the classical notion of resultant over a variety X. Then we extend it to varieties which are parameterized on a dense open subset and give new conditions for the existence of the resultant over these varieties. We prove that any maximal nonzero minor of the corresponding Bezoutian matrix yields a nontrivial multiple of the resultant. We end with some experiments.
main.pdf (207.46 Ko) Télécharger le fichier
inria-00096842 , version 1 (24-09-2006)
  • HAL Id : inria-00096842 , version 1
Laurent Busé, Mohamed Elkadi, Bernard Mourrain. Generalized resultants over unirational algebraic varieties. Journal of Symbolic Computation, 2000, J. Symbolic Comput., 29 (4-5), pp.515--526. ⟨inria-00096842⟩
149 Consultations
184 Téléchargements
