Robust Task Scheduling in Non-Deterministic Heterogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Ziao Shi
  • Fonction : Auteur
Emmanuel Jeannot
Jack J. Dongarra
  • Fonction : Auteur
The paper addresses the problem of matching and scheduling of DAG-structured application to both minimize the makespan and maximize the robustness in a heterogeneous computing system. Due to the conflict of the two objectives, it is usually impossible to achieve both goals at the same time. We give two definitions of robustness of a schedule based on tardiness and miss rate. Slack is proved to be an effective metric to be used to adjust the robustness. We employ -constraint method to solve the bi-objective optimization problem where minimizing the makespan and maximizing the slack are the two objectives. Overall performance of a schedule considering both makespan and robustness is defined such that user have the flexibility to put emphasis on either objective. Experiment results are presented to validate the performance of the proposed algorithm.
Fichier non déposé
inria-00097244 , version 1 (21-09-2006)
Ziao Shi, Emmanuel Jeannot, Jack J. Dongarra. Robust Task Scheduling in Non-Deterministic Heterogeneous Systems. International Conference on Cluster Computing- CLUSTER 2006, Sep 2006, Barcelona, Spain. pp.1-10, ⟨10.1109/CLUSTR.2006.311868⟩. ⟨inria-00097244⟩
77 Consultations
0 Téléchargements
