Surface Reconstruction by Voronoi Filtering, Discrete & Computational Geometry, vol.22, issue.4, pp.481-504, 1999. ,
DOI : 10.1007/PL00009475
On the angular defect of triangulations and the pointwise approximation of curvatures, Curves and Surfaces, 2002. ,
DOI : 10.1016/S0167-8396(03)00077-3
URL : https://hal.archives-ouvertes.fr/inria-00071995
Geometry (vols. 1-2), 1987. ,
A local coordinate system on a surface, Proceedings of the seventh ACM symposium on Solid modeling and applications , SMA '02, 2002. ,
DOI : 10.1145/566282.566302
Curves and singularities, 1992. ,
DOI : 10.1017/CBO9781139172615
Approximation et interpolation des fonctions differentielles de plusieurs variables, Ann. Sci. Ecole Norm. Sup, vol.83, 1966. ,
Smooth surfaces, umbilics, lines of curvatures, foliations, ridges and the medial axi: a concise overview, 2004. ,
General lagrange and hermit interpolation in r n with applications to the finite element method, Arch. Rational Mesh. Engrg, vol.46, pp.177-199, 1972. ,
Restricted delaunay triangulations and normal cycle, Proceedings of the nineteenth conference on Computational geometry , SCG '03, 2003. ,
DOI : 10.1145/777792.777839
Computation of local differential parameters on irregular meshes, Mathematics of Surfaces Differential Geometry of Curves and Surfaces, 1976. ,
A novel cubic-order algorithm for approximating principal direction vectors, ACM Transactions on Graphics, vol.23, issue.1, pp.45-63, 2004. ,
DOI : 10.1145/966131.966134
Polynomial interpolation in several variables Advances in Comp, Math, vol.12, issue.4, 2000. ,
Matrix Computations, HCV52] D. Hilbert and S. Cohn-Vossen. Geometry and the Imagination, 1952. ,
Accuracy and Stability of Numerical Algorithms, 1996. ,
Parallelotopes of maximum volumes in a simplex Curve and surface fitting: an introduction. Academic, Disc. Comp. Geometry, 21 Thibert. Smooth surface and triangular mesh : Comparison of the area, the normals and the unfolding ACM Symposium on Solid Modeling and Applications, 1986. ,
On surface normal and Gaussian curvature approximations given data sampled from a smooth surface, Computer Aided Geometric Design, vol.17, issue.6, pp.521-543, 2000. ,
DOI : 10.1016/S0167-8396(00)00006-6
A survey of methods for recovering quadrics in triangle meshes, ACM Computing Surveys, vol.34, issue.2, 2001. ,
Geometric Differentiation, 2001. ,
Straightest geodesics on polyhedral surfaces, ACM SIGGRAPH 2006 Courses on , SIGGRAPH '06, 1998. ,
DOI : 10.1145/1185657.1185664
Numerical Approximation of Partial Differential Equations, 1994. ,
Computational aspects of multivariate polynomial interpolation Advances in Comp, Math, vol.3, issue.3, 1995. ,
What is a good linear element? interpolation, conditioning, and quality measures, 11th International Meshing Roundtable, 2002. ,
A comprehensie introduction to Differential Geometry (Third Ed.) Publish or Perish On multivariate lagrange interpolation, Math. Comp, vol.64, 1995. ,
Inferring surface trace and differential structure from 3-D images, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.9, pp.833-854, 1990. ,
DOI : 10.1109/34.57680
URL : https://hal.archives-ouvertes.fr/inria-00075442
Estimating the tensor of curvature of a surface from a polyhedral approximation, Proceedings of IEEE International Conference on Computer Vision, 1995. ,
DOI : 10.1109/ICCV.1995.466840
Detection of Salient Curvature Features on Polygonal Surfaces, Eurographics, 2001. ,
DOI : 10.1111/1467-8659.00531
