Service specifications to B, or not to B - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Bruno Mermet
The paper introduces a new use for the B method as a means of specifying telecommunication services with the help of abstract machines and, consequently, it defines a formal framework for studying the feature interaction problem. An interaction is defined as a violation of an invariant and is detected when combining two or more abstract machines. The current B method is extended to allow the composition of abstract machines. The B method is supported by sofware that helps the specifier of services and features. We have not only modelled services within the B technology, but we have also extended the possibilities of B through the composition of abstract machines.
Autre [cs.OH]
Fichier non déposé
inria-00098409 , version 1 (25-09-2006)
  • HAL Id : inria-00098409 , version 1
Bruno Mermet, Dominique Méry. Service specifications to B, or not to B. Second Workshop on Formal Methods in Software Practice, 1998, Clearwater Beach, Florida, USA, 8 p. ⟨inria-00098409⟩
97 Consultations
0 Téléchargements
