Mobile Robot Localization in Dynamic Environment using Places Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Olivier Aycard
  • Fonction : Auteur
  • PersonId : 829837
Pierre Laroche
François Charpillet
In this paper, we present a new method to localize a mobile robot in dynamic environments. This method is based on places recognition, and a match between places recognized and the sequence of places that the mobile robot is able to see during a run from an initial place to an ending place. Our method gives a coarse idea of the robot's position and orientation. Moreover, we can determine the actual state of places (i.e open doors, closed doors).
Fichier non déposé
inria-00098427 , version 1 (25-09-2006)
  • HAL Id : inria-00098427 , version 1
Olivier Aycard, Pierre Laroche, François Charpillet. Mobile Robot Localization in Dynamic Environment using Places Recognition. IEEE International Conference on Robotics and Automation, 1998, none, 6 p. ⟨inria-00098427⟩
49 Consultations
0 Téléchargements
