Alternative Assignment and Sequencing on 2-Parallel Machine problem under constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
The purpose of this article is to present a resolution method applied on an industrial problem. This problem is a parallel machine problem with some constraints and the objective is to find a feasible solution with a minimum cost.
Fichier non déposé
inria-00098488 , version 1 (25-09-2006)
  • HAL Id : inria-00098488 , version 1
Antony Vignier, Sven Wagner, Marie-Claude Portmann. Alternative Assignment and Sequencing on 2-Parallel Machine problem under constraints. 6th Int. Workshop on Production Management & Scheduling - WPMS, 1998, Istanbul, Turkie, pp.324-328. ⟨inria-00098488⟩
36 Consultations
0 Téléchargements
