Reconstructing a Hamiltonian Cycle by Querying the Graph: Application to DNA Physical Mapping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 1998
Vladimir Grebinski
  • Fonction : Auteur
  • PersonId : 755985
  • IdRef : 193209039
This paper studies four mathematical models of the multiplex PCR method of genome physical mapping described in \cite{Sorokin1}. The models are expressed as combinatorial group testing problems of finding an unknown Hamiltonian cycle in the complete graph by means of queries of different type. For each model, an efficient algorithm is proposed that matches asymptotically the information-theoretic lower bound.
Autre [cs.OH]
Fichier non déposé
inria-00098545 , version 1 (25-09-2006)
  • HAL Id : inria-00098545 , version 1
Vladimir Grebinski, Gregory Kucherov. Reconstructing a Hamiltonian Cycle by Querying the Graph: Application to DNA Physical Mapping. Discrete Applied Mathematics, 1998, 88 (1-3), pp.147-165. ⟨inria-00098545⟩
76 Consultations
0 Téléchargements
