On the Power of Additive Combinatorial Search Model
We consider two generic problems of combinatorial search under the additive model. The first one is the problem of reconstructing bounded--weight vectors. We establish an optimal upper bound and observe that it unifies many known results for coin--weighing problems. The developed technique provides a basis for the graph reconstruction problem. Optimal upper bound is proven for the class of $k$--degenerate graphs.
