Implicitizing rational hypersurfaces using approximation complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2005
Laurent Busé
Marc Chardin
We describe an algorithm for implicitizing rational hypersurfaces with at most a finite number of base points, based on a technique already described by Busé and Jouanolou, where implicit equations are obtained as determinants of certain graded parts of an approximation complex. We detail and improve this method by providing an in-depth study of the cohomology of such a complex. In both particular cases of interest of curve and surface implicitization we also present algorithms which involve only linear algebra routines.
volos-def.pdf (214.09 Ko) Télécharger le fichier
inria-00098676 , version 1 (25-09-2006)
  • HAL Id : inria-00098676 , version 1
Laurent Busé, Marc Chardin. Implicitizing rational hypersurfaces using approximation complexes. Journal of Symbolic Computation, 2005, 40 (4-5), pp.1150--1168. ⟨inria-00098676⟩
166 Consultations
159 Téléchargements
