W. Bruns and J. Herzog, Cohen-Macaulay rings, Cambridge Studies in Advanced Mathematics, vol.39, 1993.
L. ´. Busé, Etude du résultant sur une variété algébrique, 2001.
L. Busé, D. Cox, and C. Andrea, IN THE PRESENCE OF BASE POINTS, Journal of Algebra and Its Applications, vol.02, issue.02, pp.189-214, 2003.
DOI : 10.1142/S0219498803000489
L. Busé and J. Jouanolou, On the closed image of a rational map and the implicitization problem, Journal of Algebra, vol.265, issue.1, pp.312-357, 2003.
DOI : 10.1016/S0021-8693(03)00181-9
D. Cox, R. Goldman, and M. Zhang, On the Validity of Implicitization by Moving Quadrics for Rational Surfaces with No Base Points, Journal of Symbolic Computation, vol.29, issue.3, pp.419-440, 2000.
DOI : 10.1006/jsco.1999.0325
A. David and . Cox, Equations of parametric curves and surfaces via syzygies In Symbolic computation: solving equations in algebra, geometry, and engineering, Contemp. Math, vol.286, pp.1-20, 2000.
D. A. Cox, T. W. Sederberg, and F. Chen, The moving line ideal basis of planar rational curves, Computer Aided Geometric Design, vol.15, issue.8, pp.803-827, 1998.
DOI : 10.1016/S0167-8396(98)00014-4
D. Carlos and . Andrea, Resultants and moving surfaces, J. Symbolic Comput, vol.31, pp.585-602, 2001.
J. Herzog, A. Simis, and W. V. Vasconcelos, Koszul homology and blowing-up rings, Commutative Algebra (Trento Lecture Notes in Pure and Appl. Math, vol.84, pp.79-169, 1981.
C. M. Hoffmann, Geometric and solid modeling : an introduction, 1989.
C. Huneke and M. E. Rossi, The dimension and components of symmetric algebras, Journal of Algebra, vol.98, issue.1, pp.200-210, 1986.
DOI : 10.1016/0021-8693(86)90023-2
J. Jouanolou, Résultant anisotrope: Compléments et applications, Electron. J. Combin, vol.3, issue.2, 1996.
T. W. Sederberg and F. Chen, Implicitization using moving curves and surfaces, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques , SIGGRAPH '95, pp.301-308, 1995.
DOI : 10.1145/218380.218460
A. Simis and W. V. Vasconcelos, The Syzygies of the Conormal Module, American Journal of Mathematics, vol.103, issue.2, pp.203-224, 1981.
DOI : 10.2307/2374214
W. V. Vasconcelos, Arithmetic of Blowup Algebras, 1994.
DOI : 10.1017/CBO9780511574726
