On the irreducibility of multivariate subresultants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2004
Let $P_1,\ldots,P_n$ be generic homogeneous polynomials in $n$ variables of degrees $d_1,\ldots,d_n$ respectively. We prove that if $\nu$ is an integer satisfying ${\sum_{i=1}^n d_i}-n+1-\min\{d_i\}<\nu,$ then all multivariate subresultants associated to the family $P_1,\ldots,P_n$ in degree $\nu$ are irreducible. We show that the lower bound is sharp. As a byproduct, we get a formula for computing the residual resultant of $\binom{\rho-\nu +n-1}{n-1}$ smooth isolated points in $\PP^{n-1}.$
irrsubres.pdf (119.16 Ko) Télécharger le fichier
inria-00098679 , version 1 (25-09-2006)
  • HAL Id : inria-00098679 , version 1
Laurent Busé, Carlos d'Andrea. On the irreducibility of multivariate subresultants. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2004, 338 (4), pp.287--290. ⟨inria-00098679⟩
123 Consultations
183 Téléchargements
