On the closed image of a rational map and the implicitization problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2003
In this paper, we investigate some topics around the closed image $S$ of a rational map $\lambda$ given by some homogeneous elements $f_1,\ldots,f_n$ of the same degree in a graded algebra $A$. We first compute the degree of this closed image in case $\lambda$ is generically finite and $f_1,\ldots,f_n$ define isolated base points in $\Proj(A)$. We then relate the definition ideal of $S$ to the symmetric and the Rees algebras of the ideal $I=(f_1,\ldots,f_n) \subset A$, and prove some new acyclicity criteria for the associated approximation complexes. Finally, we use these results to obtain the implicit equation of $S$ in case $S$ is a hypersurface, $\Proj(A)=\PP^{n-2}_k$ with $k$ a field, and base points are either absent or local complete intersection isolated points.
approxcpx.pdf (365.01 Ko) Télécharger le fichier
inria-00098682 , version 1 (25-09-2006)
  • HAL Id : inria-00098682 , version 1
Laurent Busé, Jean-Pierre Jouanolou. On the closed image of a rational map and the implicitization problem. Journal of Algebra, 2003, 265 (1), pp.312--357. ⟨inria-00098682⟩
382 Consultations
326 Téléchargements
