Automatic 3D Reconstruction of the Beating Left Ventricle Using Transthorasic Echographic Images - Archive ouverte HAL Access content directly
Conference Papers Year : 1998
In this paper we present an algorithm for 3D reconstruction of the beating left ventricule from echocardiographic image sequences. We especially stress on the automatic tracking process of the ventricular wall. Our algorithm is based on a combination of active shape modelling (snakes) and methods for computing the ventricular wall motion between two frames. We also investigate anisotropic diffusion filtering methods to improve the ventricule detection. Results are presented whi ch prove the efficiency of our method.
98-R-336.pdf (213.97 Ko) Télécharger le fichier
Dates and versions
inria-00098718 , version 1 (26-09-2006)
Identifiers
  • HAL Id : inria-00098718 , version 1
Cite
Marie-Odile Berger, Nicolas Maurice, Goetz Winterfeldt, Jean-Paul Lethor. Automatic 3D Reconstruction of the Beating Left Ventricle Using Transthorasic Echographic Images. Computers in Cardiology, 1998, Cleveland, 5 p. ⟨inria-00098718⟩
51 View
39 Download
Share
