Computer Vision Methods for Registration: Mixing 3D Knowledge & 2D Correspondences for Accurate Image Composition
Gilles Simon 1 Vincent Lepetit 1 Marie-Odile Berger 1
1 ISA - Models, algorithms and geometry for computer graphics and vision
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : We focus in this paper on the problem of adding computer-generated objects in video sequences. A two-stage robust statistical method is used for computing the pose from model-image correspondences of tracked curves. This method is able to give a correct estimate of the pose even when tracking errors occur. However, if we want to add virtual objects in a scene area which does not contain (or contains few) model features, the reprojection error in this area is likely to be large. In order to improve the accuracy of the viewpoint, we use 2D keypoints that can be easily matched in two consecutive images. As the relationship between two matched points is a function of the camera motion, the viewpoint can be improved by minimizing a cost function which encompasses the reprojection error as well as the matching error between two frames. The reliability of the system is shown on an encrustation of a virtual car in a sequence of the Stanislas square.
Type de document :
Communication dans un congrès
International Workshop on Augmented Reality, 1998, San francisco, USA, 15 p, 1998
Liste complète des métadonnées
https://hal.inria.fr/inria-00098719
Contributeur : Publications Loria <>
Soumis le : mardi 26 septembre 2006 - 08:19:56
Dernière modification le : jeudi 11 janvier 2018 - 06:19:48
Document(s) archivé(s) le : mercredi 29 mars 2017 - 12:44:30
Fichiers
  • HAL Id : inria-00098719, version 1
Collections
Citation
Gilles Simon, Vincent Lepetit, Marie-Odile Berger. Computer Vision Methods for Registration: Mixing 3D Knowledge & 2D Correspondences for Accurate Image Composition. International Workshop on Augmented Reality, 1998, San francisco, USA, 15 p, 1998. 〈inria-00098719〉
Métriques
Consultations de la notice
182
Téléchargements de fichiers
80
